km-3530 jamming from deck
  • copydr
    • Jan 2008
    • 6
    Has anyone had trouble with a deck jamming? The paper jams just before the timing roller. It only jams out of the deck when running letter size paper, legal will run fine. I have changed all the feed tires, sensors, switched cassettes and feed units, ... any thoughts?
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Make sure the blue and yellow feed rollers are actually touching each other. inside of the lower left access door. (PF-73?)
    Also check that the one way clutches in the lcc are ok.
    I know what I know better than anyone else knows what I know.
    • 10871087
      • Jan 2005
      • 1062
      What Jam # are you getting? is the paper just stopping or is it getting crunched?
      • Two Medicine
        • Sep 2007
        • 20
        3530 deck problem
        Some years ago lift motor problems associated with jam removal and firmware was damaging the deck main board, but that generally effected the entire deck. Upgraded firmware generally took care of the problem. On rare occassion though, I have seen the main board on the machine not generate switch timing for a specific size paper. Does the machine feed the letter 11 x 8.5 or 8.5 x 11R at all. You've probably already reseated the connectors on the deck board, but wouldn't hurt to check main board. I have probably only seen this twice in the last 4 years or so, but it can happen.
