kyocera 4050
  • raztech
    • Dec 2008
    • 88
    kyocera 4050
    code error c6030 in kyocera 4050.
    would someone like to help me about
  • Eric1968
    • 2458
    Re: kyocera 4050
    Defective thermistor in Fusing Unit. Check/Replace the Fusing Unit and reset with U163.
    • ES-OGT
      • Aug 2011
      • 129
      Re: kyocera 4050
      It doesn't hurt to try resetting first. I've actually had those codes come up due to extreme weather changes.
      If it doesn't reset after one try then Eric1968 was correct.
      • JustManuals
        • Jan 2006
        • 9838
        Re: kyocera 4050
        Paul@justmanuals.com
        • Max
          • Oct 2011
          • 552
          Re: kyocera 4050
          There is a mod bulletine. You need to replace the housing and the fuser connector at the back of the the copier.Or thermistors need a bit of a clean.
