PDF PRINTING
  • Wilf
    • Sep 2011
    • 7
    [Misc] PDF PRINTING
    Hi All
    I have a customer with a Kyocera TA 250ci. They create their own PDF's through InDesign, but when they print them out it shows all the layers in the print. If I select "print as image" in the advanced section of the print dialogue box that comes up, that clears the issue, however the result of this is slow printing.
    I have installed the machine using the KX driver on a KPDL setting (data pass through unchecked) and Kyocera first suggested changing to a PCL driver, but this doesn't help. the second suggestion is using the single KPDL driver but this has reduced functionality.
    any ideas?
  • rashid120
    • Jun 2010
    • 76
    Re: PDF PRINTING
    The TASKalfa 305/255 can dramatically lower your TCO total cost of ownership...Kyocera's SMARTtech is affordablelease download the latest KX 5.2 printer Driver.same problem was solved by updating the Printer Driver.
    Thanks And Regards-Rashid Iqbal
    • Wilf
      • Sep 2011
      • 7
      Re: PDF PRINTING
      Hi Thanks for the reply. I think I have tried every driver possible for this model, kyocera tech have had a sample document and that printed ok for them. May have to try again on other machines? The sample also printed fine to a Ricoh mp c??
