My KM 4035 I turn on the copier and the port eternet turon in green but.....
  • peredosam
    • Aug 2025
    [Electrical] My KM 4035 I turn on the copier and the port eternet turon in green but.....
    How do you reset the Kyocera km 4035 as it comes to the fabric. you now i connect the Ethernet cable to the printer port but not work, is the same cable than work whit the port of the scanner, but when i connect to the router don't turn on the led in green. i don't now what happent.the cable whit the scanner works good. tks
    Samuel
  • rashid120
    • Jun 2010
    • 76
    Re: My KM 4035 I turn on the copier and the port eternet turon in green but.....
    you have broken Ethernet connection in the machine repair other wise you have to change the Main PCB
    Thanks and Regards
    Rashid Iqbal
    • habik
      • 2013
      Samuel
      Make sure the Print board is fully inserted inside the machine, just take the little back cover off(1 screw) and you will see if it is properly conected.
      Do you get the PRINTER menu on screen?
      If it is connected properly to Main Board, then try and ping the print board from your PC, if that fails try through the Firmware Network Utility, that usually finds any KYOCERA board through Mac address...and try and load new Firmware...I believe the IB21 is on those.
      If that fails, have a proper look inside the RJ45 connector and whilst machine Switched OFF !!!! and unplugged from mains, try and "SLIGHTLY PULL UP THE PINS" on the network port...BE CAREFUL not to pull them out completely, then try and reconnect.
      The pull up usually helped me with bad connections on 5050's.
      Good Luck.
      Firmwares HERE
