KM 3530 Password Reset
  • sysroute
    My company just purchased a KM 3530 from craigslist. The unit came with a password already setup, but we have no idea what it is. What is the process to reset the password? Also, we are looking to add fax capability as it doesn't appear to have a fax board installed. What does that normally run?
    Thanks,
    Jason
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Thanks,
    Jason
    Call a local dealer and setup a service call. Ain't nuthin' free, Jason
    I think a fax system is $500.00, installed by a qualified service technician.
    I know what I know better than anyone else knows what I know.
    • sysroute
      I ask because I'm sure that if I'm told how, I can do this myself. If it's as simple as pulling a battery off a board or something of the sort I can save us the cost of a technician. If you know the solution, please let me know.
      Thanks,
      Jason
      • 10871087
        • Jan 2005
        • 1062
        Thanks,
        Jason
        Call a tech, it will be money well spent AND the fax system will cost you much more then $500 unless you can find a used one. Call a dealer with a well trained technician for this one. The original fax system for that machine is no longer available. there was a replacement fax but they are also pretty close to being discontinued. Besides the parts you need to install with the fax system (it's not as simple as a slide-in card) you will need to upgrade the firmware on the copier and also install a firmware change on the fax system to get the newer style fax system with the older copier.
        • dogsbody
          • Jun 2007
          • 289
          another option for the management code would be to read your user manual, if you don't have one, you can download one from kyocera. It will tell you how to change the codes and turn management codes on or off.
          The force will be with you always.
            • 30390
            reset
            6482 should get you in
