Home office - copier limited space
  • cam81572
    • May 2025
    I have a remote office location in my home. My home office has a Kyocera KM-2560. I am looking for a similar copier.
    I have limited space 27 x 27.
    I am looking for a quality scannerwith the copier. I am looking for quality with small file size. I have a Fujitsu 6130 and the quality and file size is not good. The Kyocera gives good quality and small file size.
    Quoted
    Copystar - 255 multi- functional . My boss is asking if this is a good brand. I was told it had Kyocera Technology. Does anyone know how the scanner quality and file size it?
    Konica Minolta bizhub 25 - Good? Scanner ??
    Sharp MX-B402SC- Good? Scanner?
    Which is better? They are basically the same based on the specs.
    Thanks for any help!!
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Home office - copier limited space
    Other than the crazy grey page problem from the main PWB goin out I've not had any problems out of the 255,305, 205c, or 255c. But that issue is supposed to be fully resolved now on new machines. They are small machines for sure. They call them the "hobbit" machines here around the shop.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • ES-OGT
      • Aug 2011
      • 129
      If you don't need to use 11X17 paper, I would recommend a KM-3540 or 3640. The only difference between these machines is the 3640 has fax capability.
      • Mooseface2r
        • Jan 2011
        • 114
        We have had alot of problems with the 255's,
        if i was you and you didnt need 11X17. i would either go for the
        Bizhub C25 - if you need colour
        or the KM-3540 - if you want just a mono
        if you wanted an easier to function machine the C35 is another option - bit better with the touch screen.
        • Dougtech
          • Apr 2011
          • 113
          I would stay away from the Sharp letter/legal machine. Dealer I used to work for quit selling them due to all the issues with them.
          my opinion: Kyocera and konica are both good. Konica has a higher operating cost on most units, but I think their color prints are better quality than Kyocera.
          • Mooseface2r
            • Jan 2011
            • 114
            Just nOticed you were talking about the Konica bizhub 25, between this and they Kyocera I'd take the kyocera
            • ignacio.cortez
              • Jul 2010
              • 176
              Quoted
              I've supported both KyoceraMitas and KonicaMinolta, Copystar is a KyoceraMita under a different brandname.
              I hated the KonicaMinolta, it has great quality dont get me wrong, but when is time to work on it, it is a pain in the neck
              KyoceraMita/Copystar are easier to work with and easier to support, in some cases you dont even need tools to replace
              Supplies or even some parts
