Kyocera 2550 Error C3200
  • Rivered
    • Sep 2025
    [Error Code] Kyocera 2550 Error C3200
    I Have a Kyocera 2550 that is giving me a C3200 error code. What is happening is, it will not copy and is erroring out on me. I have cleaned the lenses, guide track and removed all smudges from the mirrors. The mirrors are installed properly as far as I can tell. I have gotten it to work by leaving the cover off that surrounds the main optical lense. It will work fine then except it puts lines through the paper, but as soon as I either replace that cover or put the lid down on the scanner, it will error out on me.
    Thank you in advance, any and all help would be appreciated.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Kyocera 2550 Error C3200
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Try to adjust and clean the shading plate. Looks like bad shading to me.
      • aborad
        • Aug 2011
        • 61
        check 6pin flat cable continuity or replace it . also check Scanner home position Switch.
        • ES-OGT
          • Aug 2011
          • 129
          I've also see the CCD get dirty and cause the same problem. Don't remove it or blow canned air on it but just use your breath and you should be ok.
          • alexkim
            • Jun 2011
            • 9
            Go to Maintenance mode U61. If lamp is on , Check first inverter PCB, second ,Cable (carefully) and lamp (defect)
            if no problem, replace engine PCB.
