KM-3035 NW-FAX Question/Problem
  • Edge311
    I have this setup so that faxes are emailed to a single user(fax@xxx) The problem I am having is that the faxes are making it to the RX folder but some are being dropped(best way I can think to describe it) and not being set to fax@xxx. I can retrieve them manually by going to the RX folder but I shouldn't have to and would only do so if someone asks for a fax that did not go to email. I hope this makes sense.
    Thanks for any input you could provide.
    • 30421
    fax
    you have to setup email on copier
    smtp information
    if its not set email will not work
