Force firmware update
  • West Texas Flash
    • 10
    I had a print system U that encountered a card read error during firware upgrade which has taken out the print system with a C-0240 code. Any attempts to reload load have failed so far. I know the system is good if I can get the firmware loaded. Is there a secret to forcing an update that I am not aware of?
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    KM tech support might be able to access the print system remotely.
    I know what I know better than anyone else knows what I know.
    • just a tech
      • Jan 2007
      • 332
      only thing i have on this probably isn't gonna work for ya but ya never know..worst thing that'll happen is it won't work and you'll have to call kyocera tech support..so, here ya go.. good luck.. let us know what ya come up with..
      • West Texas Flash
        • 10
        Thanks, I have that and your right, it didn't work
        • milan
          • Jan 2007
          • 25
          I think you cannot do anything unless you send the DIMM to KYOCERA for reprogramming.
