Kyoceramita 2050 Network Scan
  • Nelo
    • Jun 2025
    First time setting up a kyocera Mita 2050, machine is printing and copying ok. My problem here is with the network scan setup. I seem to fail at evry attempt can some one give me a step by step guide on how to setup network scan for this machine.
  • kkendric
    • 301
    Re: Kyoceramita 2050 Network Scan
    The TASKalfa 305/255 can dramatically lower your TCO total cost of ownership...Kyocera's SMARTtech is affordable
    Just click on the above it will take you to the manuals for this machine at the Kyocera Mita cinsumer site, includes scan setup.
    • blaze2000
      • Sep 2010
      • 232
      Not to be insulting or anything but, you do have the scan card option installed, correct? Not just the one printer card. Also you need to install (and have runnning) the scan user software that will communicate from your PC to the 2050.
      • Nelo
        Yes, scan card installed.
        • Nelo
          Thanks.
          • Sam Tofu
            • Dec 2007
            • 130
            Another scan set-up question on this. We had the 2050 set up to scan to Desk Top Folder on XP. Customer got Win7 64 bit. Our other tech just went out. Installed File utility, Folders , Set up user browser IP link etc. But couldn't get to work.
            Is there a trick or something on Windows 7. Can you scan to folder as before.
            Thanks in advance
            • Cape Town Boy
              • Oct 2010
              • 13
              Thanks in advance
              Have you tried adding the Scanner file utility to the firewall?
              • Jude
                • Oct 2009
                • 256
                PM me and give me some rep power and I will give step by step.
