Kyocera KM 2030 error C710
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I attended a KM 2030 with error C710 which apaarently has only occurred since moving the machine. . . .
    I have checked the connectors to the imaging unt and toner motor.
    When I enter U135 in diagnostics, the motor turns on fine and switches off.
    I have then entered U132 which runs for 4-5 seconds then stops. The INPUT value begins at 15 then counts down to around 8!
    If I try run U135 after, the green start buttion does not come ready and the U135 will not run until i power off and on again.
    The SM says to replace the toner sensor and check wiring then replace Dev. . .
    Is there anything anyone can add before I order up the toner sensor and dev??
    Is there anything I need to replace at the same time as the toner sensor and dev?
    Many thanks!
  • kkendric
    • 301
    Re: Kyocera KM 2030 error C710
    Try an all clear Sim 20, if comes back up in metric sizes do a 252 to set back to inch. If that fails you might have a board problem. I have done this to several boards and it took care of the problem. There is also a surface mounted fuse and a coil that sometimes go on these boards.
    • taskalfaman
      • Nov 2009
      • 137
      change de developer (carrier)
      run sim 130
      problem should be solved=> if not change complete unit.
      best regards.
      • kyocera.team
        • Aug 2010
        • 126
        try to change developer if the problem still there you need to change the main PWB
