FS-2020 with Problem Service Call 4200
  • mogolitos
    • Jul 2025
    Hello,
    I have a Problem with my Printer FS 2020.
    The Service Call 4200 is the Laser units not OK, but in this case, the Laser Unit is OK.
    I have more Printers with the same Symptom. My Problem is, I don't find the defect??
    Can you help me?
    Thank
    Sorry for my not so Perfect English, Is possible to answer of German or French
    Thank you ....
  • HenryT2
    • 962
    Re: FS-2020 with Problem Service Call 4200
    Have you up-dated the firmware ?
    Have you checked the wiring harness ?
    Have you checked the voltages ?
    Have you replaced with a KNOWN GOOD laser ?
    Try the above and if you get still get the error , you may need to replace the Main or the Engine board.
    Good luck
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • mogolitos
      Hello,
      You can see the Event log from Printer.
      The Problem is from time to time.
      I checked the wiring harness --> OK
      I checked the voltages --> OK
      Have you replaced with a KNOWN GOOD laser ? No, the Laser is new and OK 100%
      You have a Idee of my Problem ?
      thanks
      • mogolitos
        Have you a new firmware for this Printer ?
        • HenryT2
          • 962
          If you are a Certified Tech ; you can just download the firmware from Kyocera .
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
