Hi Guys, When it comes to the Kyocera line, I am definitely the new kid on the block. I have a relatively new (about 100k) 5500i. I am, in U031, getting a constant high of the Exit Feed Sensor. I swapped out the sensor and it came up, ran for a day, and went right back down again, same problem and symptoms. I went back with a new sensor and swapped it out. However, now it is a constant False Jam. The Exit Paper side of the sensor does work correctly. Just for grins and giggles, I swapped out the sensor again and the false jam remains. If I disconnect the Eject Assembly, the machine will initialize normally. For what I can see on the schematic, it seems a pretty basic path from the sensor through the FRPWB and back to the EPWB.
I was just curious if anyone has seen this kind of trouble in this area before.
Thanks in Advance and have a GREAT weekend.
Doug
Doug
