FS-6030MFP (Check the toner container)
  • dynsam
    • Apr 2011
    • 21
    A new FS6030MFP straight from the box. Indicate an error. Message showing on the display panel (Check the toner container. Open the front cover of the machine and pull out the toner container. Shake the container well and reinstall it).
    Tried 4x toner cartridge but still the same. Run U031, U147 and U150. All of the switches, sensors and motor are ok. they seem to be running ok.
    Please need assistant from you all.
    thanks in advance
  • kaborwen
    • Feb 2010
    • 146
    Re: FS-6030MFP (Check the toner container)
    thanks in advance
    I never experience this issue but try to change toner contener.
    • drazen7777
      • Sep 2010
      • 40
      Hy
      You will have to change the engine board , problem with chip capacitor that is mounted on the Toner container detection circuit of the Engine board(kyocera has bulletin for this problem )
      Regards
      Drazen
      Technician -- a person who fixes the mistakes made by engineers.
      • dynsam
        • Apr 2011
        • 21
        thank you very much Drazen and all of you for the information
