KM FSC 8020 mfp problems after main pcb changed
  • tekkie
    • Mar 2011
    • 111
    [Misc] KM FSC 8020 mfp problems after main pcb changed
    I have a kyocera mita FSC 8020 mfp that has had a main pwb changed due to a fault this is the one with the network connector on it. After changing it the original fault is cured but im left with 2 other problems.
    that werent there before. First there is a message on the screen saying finisher fault even though there is no finisher on the mc and secondly the mc wont scan.Its not that the scan is failing its just nothing happens when you try to scan to folder or scan to email the button goes green when you select the scan but it doesnt scan either thro the doc feeder or from the glass when the button is pressed-nothing at all happens The doc feeder is working fine when scanning for a copy but nothing happens when you press the button for scan and it doesnt error or anything.Any ideas please would be appreciated.
  • blsquires
    • Nov 2008
    • 342
    Re: KM FSC 8020 mfp problems after main pcb changed
    couple of things have you changed over the eprom from the old board .have you done a firmware update as it wont take sometimes the first time you try it.do the update again then a 906 and see if that fixes your problem.
