Excessive Toner Consumption
    • 30441
    #16
    toner
    2630 is not a great model for them.
    Is firmware current? also does it have newer style dev units all colors?
    Installed new corona units?
    Also have you clean the led heads?
    • Rune
      IT Technician
      • Mar 2008
      • 15
      #17
      Firmware ver
      This firmware ver. is the best for toner saving.
      If you use older or newer firmwares the machine fill up the waste toner box very fast.
      Main P2BG3822.0A1
      MMI P2BG3823.0A0
      Lang P2BG2934.5G2
      Set this parameter in service mode.
      U131 135 145 145 145
      /Rune
        • 30441
        #18
        Current Firmware Level
        Program No.
        Check SUM
        Ver.
        SCANNER
        2BG2931CR
        E621
        292
        ENGINE
        2BG2932ET
        2C6C
        181
        Updated
        LANGUAGE A
        2BG29334F
        4CA2
        62
        When upgrading firmware or replacing board etc., please upgrade 3 types of firmware (MAIN, MMI, LANGUAGE, etc.) to the latest versions posted on KMAconnect.
