Jam 4211/4212 on 4500I
  • monstott2010
    • Jul 2025
    Getting multiple jams in exit section, single or duplex, would run ok if manually lifting switchback section guide. Replaced solenoid. No change. Found spring did not have enough tension to lift switchback correctly. Replaced with higher tension spring (used red spring from 6030/8030 drawers - same length) and tested operation - ok.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Jam 4211/4212 on 4500I
    There was a mylar mod for the gates, there is a new style exit unit
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
