False "set toner cartridge" message on a CS-2550.
  • itek8301
    • Jun 2010
    • 14
    Cs- 2550 with OEM TK-423 Gives false set toner cartidge message. Remove and reset TD works for a few copies and Message returns. Is there a test for the switch at back of TD holder?
  • tbsoa
    • Aug 2009
    • 15
    Re: False "set toner cartridge" message on a CS-2550.
    Your machine may need updated engine pwb.
    • dickierock
      • 252
      Hi there, is this the same as kyocera-mita 2550? If so try fold up a sheet of paper many times into a small square and wedge it between the blue/green toner lever and the toner container at the front of the machine to see if the container has too much room too move away from the switch.Good luck.
      • itek8301
        • Jun 2010
        • 14
        Replaced toner motor problem solved. Thanks
