CS-4035 scan to folder issues
  • mcreath
    [Misc] CS-4035 scan to folder issues
    I have a CS-4035, we scan to folder over a network to a folder on the local pc. The document shows up immediately, but the copier takes 2 minutes to release and come back to ready. We have updated the firmware, changed cables, changed local 4 port switch, changed port on the main switch, swapped the nic and have the same results. The same issues are evident when we scan to a laptop. What else can we try?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: CS-4035 scan to folder issues
    Try scanning with Scan File Utility
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • nmfaxman
      • 1702
      I am thinking, enable SNMP, or reduce the timeout to 30 seconds or less.
