kyocera taskalfa ci300 error c2204
  • tullio
    • Feb 2012
    • 268
    taskalfa ci300. 2012-07-02 11.54.05.jpgerror c2204. urgent.2012-07-02 12.05.38.jpg
  • Eric1968
    • 2458
    Re: kyocera taskalfa ci300 error c2204
    - Bad connection between the Y-drum motor and the engine PWB
    - Bad Y-drum motor
    - Defective engine PWB
    • tbsoa
      • Aug 2009
      • 15
      Originally posted by tullio
      taskalfa ci300. [ATTACH=CONFIG]16520[/ATTACH]error c2204. urgent.[ATTACH=CONFIG]16521[/ATTACH]
      Drum motor Y does not keep the steady- state speed for 5 s successively since
      the motor is stabilized.
      connector termi-
      nals.
      Check the connection of connector YC7 on
      the motor control PWB and the connector of
      the drum motor Y, and the continuity across
      the connector terminals. Repair or replace if
      necessary.
      Defective drum
      motor Y. Replace the drum motor Y.
      Defective PWB. Replace the motor control PWB or engine
      PWB and check for correct operat
      • tbsoa
        • Aug 2009
        • 15
        connector termi-
        nals.
        necessary.
        Defective drum
        I had a call like this but it was not the drum as the service manual says for 2204. The hvac which all drum units touch and the control board were the issue.
        • NeoMatrix
          Senior Tech.
          • 3513
          C2200 is a drum rotation code
          Remove all the developer units and check you can rotate each unit easily by hand.
          Check the developer roller(NOT toner roller) has a even coating of dev all over it.
          If you can't rotate the dev units shake sh!t out of it and keep turning it unitil you can.
          Place the units back in the machine and test.
          • tullio
            • Feb 2012
            • 268
            Thank you. same problem.
