hi all, the taskalfa 420i was working properly until some one accidently enable the key counter option and now its asking to insert the key counter. there is no key counter options installed. please how can i disable this function to get it to not ask to insert the key counter card? urgently need your help
TaskAlfa 420i-display insert key counter
Re: TaskAlfa 420i-display insert key counter
Hi madas
even if i press the job status button or enter 10871087, the pop up still stays on the screen panel asking to insert the Key Counter Card.
It just won't allow me to go into service mode.
Please any other option to try...Comment
Hi
can you get into job status or use any of the keys or is it all locked out? does it beep when you press keys?
if it is frozen all i can suggest is to try to do the firmware and see if that will do the trick. sorry not had this before.
madasComment
If you can find the key counter connector you should be able to bring the copier ready from that. The connector runs from YC19 on the EPWB to the key counter knock out on the side of the copier. It's a 4 position connector behind that knock out. Pins 3 & 4 bring the copier ready. There is 5VDC signal (Key Set Sig) on pin 3 and ground on pin 4. When the 5VDC signal brought low by being shorted to ground; the copier comes ready. Once it's ready you should be able to enter service mode and change U204.Jamex Tech Support: Saving the world one phone call at a time.Comment
