FS-6025 cannot use scan SMB
+ More Options
Posts
  • eins87
    • Mar 2012
    • 5
    [Misc] FS-6025 cannot use scan SMB
    hi,,,can anyone help me,,,fs-6025 cannot use SMB scan after i change the PWB main board, but it can scan to flashdisk.
    thanks,,,
  • habik
    • 2013
    Re: FS-6025 cannot use scan SMB
    thanks,,,
    Enable SMB in Network settings..possibly flash Firmware and enable SMB to On!
    Firmwares HERE
    • Pinoy_Tech
      • Feb 2010
      • 47
      thanks,,,
      It's common occurrence when replacing main board. We've changed a lot here and by just simply updating firmware to latest version can solve the problem.
      How to; Download the files from your technical support center then copy the entire files to any usb ( extract but don't create folder). Turn OFF the machine then insert usb to machine's usb slot (at the front right side) then turn ON the machine, just wait until completion (takes 15mins or so). OFF/ON, Done!
