km 3530 and km 2035
  • happicopy
    • 51
    km 3530 and km 2035
    I got a km3530.its running well until i saw the upper fixing roller needs replacement. what i did , i got the fixing assy from a km3035 unit that is in the stockroom , hoping for a quick fix and swap it in the km 3530. a code appears c7400. i swap back the original fixing assy but i still got the code c7400. now i cant reset the c code. any info for me? please...
    My next question is about km 2035, is there a provision for a analog meter? maybe on the main board connector perhaps??? or an option for a analog counter?.
  • kkendric
    • 301
    Re: km 3530 and km 2035
    C7400
    Image formation unit connector insertionproblem
    Absence of the image formation unit
    is detected.
    KM2530, 3530 & 4030 fusers are not the same as KM 3035, 4035 & 5035
    KM3530 Fuser # 302BJ93044
    KM3035 Fuser # 302FG93036
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • kyogenius
        • Jul 2012
        • 136
        a closer look at fuser units shows they are different ,heat rollers and pressure rollers are not the same, but more importantly the small chips/boards inside the fuser units are different so u get an error code,
        failure is not an option !
        • Dan J
          • Oct 2011
          • 25
          No, you can't swap fusers, but the error you're getting is for the image formation unit (drum unit). Didyou have the drum out?
          • happicopy
            • 51
            My bad guys...silly me for swapping the fuser..but i did not take out the drum set..only the fuser.after swapping the fuser, i just turn it on then c 7400 appears . what i did after is returned the original fuser and power on the machine, but the c7400 is still there hence cannot be reset..i 've check the drum connector hoping for a loose connection but to no avail..c 7400 is still there.is there a possibility that i damaged the main board? any suggestion ???
