the copier's waste toner bottle fills up after only 5000 copies. My tech cannot figure it out. Any help would be greatly appreciated.
I have a CS 552ci Waste Toner Problem
Re: I have a CS 552ci Waste Toner Problem
One of the dev units is probably bad, can usually see it going through more of one colorIBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications -
There was in fact a bad developer. This machine is new and the dev unit went bad at 150k. That has been replaced since my initial posting. So, the jury is out on weather the waste toner bottles are lasting any longer. I'll post data as it comes in. Thanks for the info Venom.Comment
