DF710 fin "cannot combine functions" error message copier control panel
  • copierpro
    • Apr 2007
    • 270
    I have no settings conflicting on the c4035e I am hooked up to to cause this error message on control panel when I try to select sort staple etc.; swapped out with a known working 710 same error message.Any suggestions appreciated - these are trade-ins not real familiar with them but I know crap when I see it.
  • Zackuth
    • Aug 2009
    • 448
    Re: DF710 fin "cannot combine functions" error message copier control panel
    10871087 into the maintenence mode. Type in 906 and press start. The machine should reboot and that message be gone.
    If at first you don't succeed, redefine success
    • copierpro
      • Apr 2007
      • 270
      thanks a bunch that did the trick
