Kyocera 4035 NW-FAX Confirmation Report
  • GSX115
    • May 2025
    I can't seem to find any real documentation on this. I'm trying to get confirmation reports to print from faxing on the actual machine (not from PC). Whenever I select the Print Confirmation Report button it tells me that it is not programmed. When I look in the manual it has nothing on configuring it, just how to print. There is also no mention of Confirmation Reports under the FAX Default in the machine settings. Thanks in advance!
  • GSX115
    Issue resolved. Confirmation Reports are only for TX Polling. Found that the Transaction Report printing option under FAX Default -> Report Printing was what we were looking for.
    • Rigger
      • Mar 2007
      • 30
      I had exactly the same problem 6 months ago. I just ignored/forgot about it.
      Thanks for the "heads up"
