feeding from Drawer 5 (hi cap) will run anywhere from 10 to 500 copies before jamming, checked feed rollers, cleaned sensors, no change. Test in Drawer 3 same issue, did not test other drawers but assuming same results. Error pointing to the loop sensor, paper not getting to loop sensor as it is stopping about 1 inch thru the registration roller. Since we had just recently put the upgrade kit in this machine, took the additional bar/mylar off the registration plate to test, no change. I have ordered a new sensor, but looking to see if anyone else has seen this
8000I WITH J41xx
Tags: None
Re: 8000I WITH J41xx
feeding from Drawer 5 (hi cap) will run anywhere from 10 to 500 copies before jamming, checked feed rollers, cleaned sensors, no change. Test in Drawer 3 same issue, did not test other drawers but assuming same results. Error pointing to the loop sensor, paper not getting to loop sensor as it is stopping about 1 inch thru the registration roller. Since we had just recently put the upgrade kit in this machine, took the additional bar/mylar off the registration plate to test, no change. I have ordered a new sensor, but looking to see if anyone else has seen thisComment
monstott2010
monstott2010
