kyocera mita 5035
  • selmila
    • Aug 2012
    • 133
    kyocera mita 5035
    Hi,i am unable to solve noice while printing from the machine macanisem.it is making noice while printing an it like a gear noice from behind but i dont see any gear wornout. any sugestions.
  • JR2ALTA
    • Feb 2010
    • 2014
    Re: kyocera mita 5035
    Check toner cartridge. May be bound up or missing gear teeth in back of it.
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • selmila
        • Aug 2012
        • 133
        i have checked toner cartridge and there r no missing gear teeth.would there be any drive macanesim contact problem.
        thanq.
        • Masterchief
          • Apr 2011
          • 281
          You will have to go into service mode and run each motor one by one so you can isolate this problem.
          or you can go the long way by removing the covers and doing a copy to locate where the noise comes from.
          My guess is on the registartion unit, remove the door and you will have easy acces to it. I have seen these break or get worn and cause a horrible noise when the gears get broken or become loose. My money is on this area i have had this problem maybe 5 times. Might be worth having a look at the manual and bringing a 2nd hand part with you.
          Masterchief
          sigpic
          • eddie110171
            • May 2012
            • 133
            I would say it is the middle feed unit. Try swapping it with a new one or a used one from a quiet unit. It is very easy to change.
            • copygirl
              • 75
              I have also seen the belt that drives the bypass unit make a horrible noise when the teeth on the belt wear out. The belt is in the back right over the upper lift motor. If you turn it by hand you will be able to see if any teeth are missing.
              Ginger
