Good bad or indifferent.....
Any Coments on the new Kyocera Mita Line?
Re: Any Coments on the new Kyocera Mita Line?
TASKalfa 4550ci
TASKalfa 6550ci
TASKalfa 2550ci
Well Primarily the TASKalfa 2550ci 4550ci, and the 6550ci. I'm assuming that that the 25,30 / 35,45 / 65,75 are same or similar box (ie Comsumables and performace being the same). also the BW models of the same speed...Comment
2626 good little MFD
5550 Had problem with black toner 9 month of constant trying could not get it to work unit replaced and new one fien (the 5550 and 65550 are the same family) twom sides scan excellent. staple and hole punch work well. Small issue with the fiery driver on the network but easly sloved.
Kyocera service excellent usually hear in an hour.Comment
