Kyocera 5250DN Color Printer
  • Techgal
    • Nov 2011
    • 7
    I have a customer with Kyocera 5250DN printer, the problem that I have is, they are printing a Word document and when they send it to the Kyocera there is a line that is missing. Also, the date (ex: 18 & 19)
    the bottlom part of the 18 & is missing. They printed this document to another printer that is a Samsung and it printed out fine. I am thinking that this might be a print driver problem. If so, what do I do to resolve this issue?
  • HenryT2
    • 962
    Re: Kyocera 5250DN Color Printer
    What operating system are they using ?
    What driver are they using ?
    Is this USB or network interface ?
    What is the emulation ?
    Does the 5250 have extended memory ?
    Is this sent through a print server driver or from a PC driver ?
    Check and reload the proper driver ( try the KX driver for that operating system, either 32 or 64 bit ) .
    If this is on a print server, load the driver onto the PC .
    Check to be sure the emulation on the printer and the driver match.
    If you do have extended memory, check the RAM disk settings .
    Good luck .........
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      in the driver try different emulation as suggested
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
