Kyocera 1135 Developer Calibration?
  • User Name
    Awesome Sauce
    • Nov 2009
    • 405
    Hello everyone,
    I setup a new 1135 and the developer unit was bad. I replaced it and was wondering if there's a calibration. I did the procedure in the system menu but it didn't do what I thought it should. I thought maybe it would run for a few minutes and add toner but it didn't and there was a void due to the lack of toner. The void went away after a few pages but I feel like I'm missing something.
    Any advice is appreciated. Thanks!
    Just because you're not paranoid doesn't mean they're not out to get you.
    O.o
    WARNING: My profile page can cause blindness in small children and old copier techs. View at your own risk.
  • HenryT2
    • 962
    Re: Kyocera 1135 Developer Calibration?
    Did you tell the 1135 that it had a new developer ?
    If not ... check the Service manual and follow the steps to install a new developer .
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      It's an 1135...not much you can really do about it. The MM sucks on these as about all you can really do in it is print reports, clear the maint counter, and back up an address book.
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • User Name
        Awesome Sauce
        • Nov 2009
        • 405
        Yep but it didn't do anything after I told it it had a new developing unit. I thought it would cycle or something. It just beeped and was done. The service manual also says to clear the maintance count but there isn't much point in that since the machine only has less than 100 pages through it.
        MM?
        O.o
        • HenryT2
          • 962
          MM = Maint Mode
          O K
          New MFP.....< 100 prints ..... new developer ?
          What was wrong with the original DV unit ?
          After setting 'New Developer', and power cycle; it should have done more than just beep .
          Were you getting any error codes ?
          • User Name
            Awesome Sauce
            • Nov 2009
            • 405
            MM = Maint Mode
            O K
            It was leaving dark bands down half the page right from the first copy.
            POWER CYCLE! That wasn't part of the instructions. Well, not in the version I have. I did the "New Developer" setting again and cycled the power and it did the 15 minutes of "Adding Toner" that I expected it should have done without the need to cycle the power. The copies look good and I think this thing is ready to go.
            Thanks!
            O.o
