BF730 wrinkles letter Bi-folds
  • sostek
    • May 2010
    • 80
    Good evening, we are a new dealer and have placed 3- DF790 with BF730. All wrinkle letter bi-folds,not trifolds or ledger. We have many folders on other manufacturers and have no problems with the same paper.
    Any suggestions?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: BF730 wrinkles letter Bi-folds
    We have same problem...still trying to figure out
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • sostek
      • May 2010
      • 80
      I have a call open with tech support,they say there are no reports of problems.
      • Tonerkiller
        • Oct 2012
        • 668
        I had one wrinkling because the finisher was not aligned properly
        • Venom
          • Nov 2009
          • 765
          Our rep saw issue before and had the answer. The blade that pushes up on middle of paper can be installed upside down (depending on region), flip it 180 degrees and it will be fixed!
