Copystar CS-1815 How to Update Firmware
  • jcontractor
    • Aug 2010
    • 247
  • HenryT2
    • 962
    Re: Copystar CS-1815 How to Update Firmware
    Originally posted by jcontractor
    Hi,
    I need to update the firmware for Copystar CS-1815.
    Is this the only way to upgrade it?
    Manual Said:
    Firmware upgrading requires the following tools:
    Compact Flash (Products manufactured by SANDISK are recommended.)
    If you do not believe the manual you have ..... perhaps it is not the correct manual .
    If you are a certified tech/dealer ; then you have access to the manuals ... if not ....
    Get the correct manuals from Paul .
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • jcontractor
      • Aug 2010
      • 247
      Originally posted by HenryT2
      If you do not believe the manual you have ..... perhaps it is not the correct manual . If you are a certified tech/dealer ; then you have access to the manuals ... if not .... Get the correct manuals from Paul .
      Thanks.
      • kkendric
        • 301
        The instructions that you have are correct, does copier have a fax system? if so remove it, the CF card connector is below the fax, if equipped. It is just to tht right of the connector the fax would plug into on the main board.
