SMB scanning to windows 8 or Server 2012
  • Frits
    • Jun 2009
    • 62
    maybe this is helpfull
    Disable Secure negotiate on the client windows 8 or windows server 2012 until firmware is ready for use
    • Disable "Secure Negotiate" on the client. You can do this using PowerShell on a Windows Server 2012 or Windows 8 client, using the command:
      Set-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\LanmanWor kstation\Parameters" RequireSecureNegotiate -Value 0 -Force
      Note: The command as displayed above may wrap multiple lines in your web browser.
  • Eric1968
    • 2458
    Re: SMB scanning to windows 8 or Server 2012
    Thank you - Dank je wel!
    • sunboi
      • Dec 2011
      • 34
      Hi , Sorry for asking but where should I input this string of command to disable the "secure negotiate" Thanks in advance.
      • ruben
        The New Guy
        • Oct 2012
        • 1203
        It tells you in the very first line, Windows PowerShell. If you don't know what that is or how to use it, stop now and go read up on it.
        • Aquintasii
          • Feb 2013
          • 10
          I haven't had any luck getting this command to work. I've done all the registry adjustments and gp policys. Does anyone have this working without firmware?
          • Frits
            • Jun 2009
            • 62
            if it's a problem do it this way
            Scan007126.pdf
            • Fer
              • Nov 2009
              • 267
              Would that new firmware help scanning to OSX 10.7 and 10.8?
              • Slakkie2x4
                • Jan 2013
                • 2
                smb not supported on mac 10.7 and 10.8. Use scan to mail or scan to document server
                • joel1979
                  • May 2014
                  • 2
                  Have also had problems scanning to server 2012 via SMB with Kyocera, found that default SMB port is 139 but changed to 445, which worked in this case.
                  • habik
                    • 2013
                    FTP or Email.
                    Firmwares HERE
                    • TheOwl
                      • Nov 2008
                      • 1732
                      Use the below update to assist.
                      Windows RT 8.1, Windows 8.1, and Windows Server 2012 R2 update rollup: November 2013
                      • TheOwl
                        • Nov 2008
                        • 1732
                        or
                        How to enable and disable SMBv1, SMBv2, and SMBv3 in Windows Vista, Windows Server 2008, Windows 7, Windows Server 2008 R2, Windows 8, and Windows Server 2012
