TASKalfa 7550ci vs Konica Minolta C754 which one?
  • habik
    • 2013
    I thought I will never ask this question, as I would definitely go for Konica in terms of colour output.
    I just want to know your thoughts on this subject.
    Many Thanks!
    Habik
    Firmwares HERE
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: TASKalfa 7550ci vs Konica Minolta C754 which one?
    C654/C754 = buggy as all fuck currently. give it a while to iron out all the bugs.
    Dont know anything about the others as I dont work on them
    • tweakp
      If it's just one machine, I would go for the Konica because of the color output.
      If You're having more machines in a network and color is not the most important I would choose the Kyocera. Kyocera is in network environments better to work with then the Konica (lot's of problems here with Konica in enterprise environment) .
      • habik
        • 2013
        Thanks, makes sense. Appreciate your input!
        so far 1-1 no winner yet
        Firmwares HERE
        • monstott2010
          Out of the gate the 7550CI has had a lot of issues, but they are slowly working some of them out... still have plenty of issues to go, but getting better..
          • fourl6
            • Nov 2008
            • 94
            Toshiba e-Studio 6550C?
            65ppm Colour, 75 Mono
            Fantastic machine if you have technicians that know how to maintain and repair them.
            Love the image quality, extremely consistent (unlike the Kyocera)
            • taskalfaman
              • Nov 2009
              • 137
              just go for the TA-7550CI.
              great machine, great speed, great design, and stable.
              • habik
                • 2013
                We have few 8000i and not exactly reliable, considering is the same box, is the colour newer phase as for example the 8000i has a new version with all the mods in.
                Firmwares HERE
                • fourl6
                  • Nov 2008
                  • 94
                  - Yellow backgrounds
                  - Fuser belts tearing
                  - Charge rollers needing a clean every 80,000
                  - Attention lights stuck on for no reason (906)
                  - Developers and charge rollers rated life has now been halved
                  The only issue i ever had with the Toshiba es6530c series
                  - Fusers needing a rebuild at around 150k (rated at 300)
                  - Fuser drive units stripping (fixed with es6550c series, and modified drive unit also fixed es6530 series)
                  15 machines and not 1 image quality issue that wasn't caused by the fuser unit or drum units running over there rated life.
                  I'm sure kyocera will fix the issues and the im comparing a Series 1 Kyocera with a Series 2 Toshiba but i still dont think the kyocera will ever match the toshibas copy quality consistency.
                  Cheers.
