Kyocera 8000i error C2550
  • vmchong
    • Oct 2008
    • 22
    [Error Code] Kyocera 8000i error C2550
    Does someone resolve this code c2550? I had try everything the manual said. HELP PLS!
    The manual said:
    Transfer motor error
    After transfer motor is driven,
    the ready signal does not turn
    to L within 2 s.
    After transfer motor is stabilized,
    the ready signal is at the
    H level for 1 s continuously
  • habik
    • 2013
    Re: Kyocera 8000i error C2550
    to L within 2 s.
    What firmware have you got?
    Firmwares HERE
    • monstott2010
      had this with a new transfer assy in maint kit... put the old one back and ran fine... yes, fw is up to date
      • vmchong
        • Oct 2008
        • 22
        Thanks for the info, but the machine yet to do upgrade kit. I'm ordering the Fuser motor on a way, will update the outcome soon.... FW V: 2LF_2F00.003.158 2012.07.18
        • Del Clack
          • Jun 2008
          • 8
          Hi, had this other day after adjusting the fuser bracket without a jig. Revisited and realigned with jig and also saw the fuser drive was very stiff and not running freely as it should. Stripped out the drive and cleaned off all grease/oil someone had squirted in there and run as free as anything. Nasty job to refit mind...
          Error not returned since though!!
          • linuxgyro
            • Oct 2012
            • 45
            i had this just yesterday, i replaced the transfer unit, since the cover over the motor was jammed into the flywheel and causing it to bog down. that put strain on the motor and caused it to fail. perhaps the issue is related to the cover rubbing the motor flywheel.
            • vmchong
              • Oct 2008
              • 22
              Thanks will give a try, ordered fuser motor drive unit on the way.
              • tech07
                • Aug 2008
                • 410
                I had this code last week after replacing the transfer belt assembly during a PM. Turns out I had slightly pulled out the connector for the motor on the PCB end. It looked like it was ok, but when I pushed on it, it snapped into place correctly
                • FINGERS123
                  • Nov 2012
                  • 33
                  There is a contact on the back of the transfer belt on the motor side that gets covered with toner and cause arching which cause that code. Remove transfer belt clean the contacts and your code will go away.
                  • vmchong
                    • Oct 2008
                    • 22
                    Yes! it is the contact. Thanks
