i faced problem in TAS-8000i registration Jam-4013. i checked the registration sensor,its working fine.the machine done only 5k. copies.before it having problem jam-4208...after updating the firmware its having intermittent JAM-4013.this problem happening in duplex mode. simplex is working fine and no problem found.any help???thanks
JAM-4013 in TAS-8000i
Re: JAM-4013 in TAS-8000i
Have you tried checking out recent Service Bulletins from Kyocera? That will help you a lot. -
20130906_074932.jpgCheck the white rollers that press on the pre-reg roller. They should turn freely when the door is open. Page 80 item 21 is the roller holder. It will break.Comment
