km 2550
  • Saji
    • May 2010
    • 97
    km 2550
    kyocera mita 2550 giving black band(5cm width) on the back of copiies, i cleaned charge rollers,cleaned develping unit etc. but problom still persists,pls help. thanks in advance.
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: km 2550
    If its only on the "back" of the copies, I suggest you start looking at the transfer roller/area. Or press roller in the fsr unit.
    The gene pool could use a little chlorine.
    • hekotez
      • Jan 2007
      • 91
      Re: km 2550
      Is your line more like a very dark background type thing... starts really dark then lightens up and dissapears... and at the very top of leading edge of the sheet? If so my my first guess would be the toner (probably non OEM?)...
      • JustManuals
        • Jan 2006
        • 9865
        Re: km 2550
        This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
        Paul@justmanuals.com
        • monstott2010
          Re: km 2550
          Lines can be caused by several different things.. scan and post if possible, otherwise more description would help as well.. is the line consistant in length/width... is it across the page or lead to trail... etc...
