I have a kyocera 5035 which comes up with an error code that says "no multi-copies" when running more than one set of 8.5x11 prints from a *.PDF file. The machine will also stop, pause and restart as its printing large sets and when it finishes the set and is about to start a new set, the error code pops up and the machine stops. This is a new problem and only happens when sending prints from the computer.
-The machine has a hard drive with jobs on it that can be run from memory but it seems the machine does not see the hard drive on the configuration print out. Any help would be greatly appreciated!
