ERROR C6400 ON KM1500
  • same_steven
    • Jun 2011
    • 52
    Dear Friends,
    I want to thank this community for the support it has encouraged among technicians.
    I have a Kyocera Mita 1500 with the error c6400.
    How do I clear it?
    Your help will be highly appreciated.
  • kkendric
    • 301
    Re: ERROR C6400 ON KM1500
    This is a zero crossing error often caused by power surges. The only clear that I know of is to do a fuser reset, simulation 163.
    • JustManuals
      • Jan 2006
      • 9919
      Paul@justmanuals.com
      • Eddie Tan
        Originally posted by same_steven
        Dear Friends, I want to thank this community for the support it has encouraged among technicians. I have a Kyocera Mita 1500 with the error c6400. How do I clear it? Your help will be highly appreciated. Thanks
        the problem maybe poor connector terminals contact of polygon motor from the PCB.Pls.try check.
        Last edited by Guest; 12-10-2012, 05:22 AM. Reason: misdiagnose: 163 is reset for fuser problem
        • same_steven
          • Jun 2011
          • 52
          Thank you so much guys but how do you get to the simulation mode?
          • kkendric
            • 301
            This is not a laser/polygon motot error. It is caused usually by power fluctuations the power supply and or engine boards cause it. Fuser clear will correct it.
            Zero-crossing signal problem
            The engine board (KP-5061) does notdetect the zero-crossing signal for thetime specified below.At power-on: 3 s
            Others: 5 s
            • kkendric
              • 301
              Press the system menu/counter key.
              Select Service setting using
              the up/down cursor keys.
              While pressing the start key and the # key,press the enter key.
              Maintenance mode is entered.
              Select Maintenance mode using the up/down cursor keys.
              Press the enter key.
              Enter the maintenance item number using the up/down keys.
              Press the enter key The selected maintenance item is run.
              After running the maintenance item you must power off/on to exit the maintenance mode.
              You might have to open the cover to enter the maint mode.
              • jummamaster
                • Mar 2009
                • 99
                This machine has slightly different method to get to the simulation mode. See this article:
                C6400 on KM1500
                Ricoh Error Codes
                Canon Error 5100
                Canon Error B200
                j
                c
                • jummamaster
                  • Mar 2009
                  • 99
                  This will not work for KM1500. It doesn't has system menu/counter key.
                  Ricoh Error Codes
                  Canon Error 5100
                  Canon Error B200
                  j
                  c
