taskalfa 520i showing offline
  • Chameleon
    • Nov 2011
    • 200
    I have one that intermittently can't print. Printer showing offline. They said it has been doing it a lot lately. What I found when I was there was tray 3 had an error. Reset with mode 906. I'm not completely sure the intermittent can't print it is related to the tray 3 error. I thought I'd ask here if anyone has seen this before?
    The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
  • Redarmy
    • Sep 2011
    • 25
    Re: taskalfa 520i showing offline
    Enter your printer properties --> ports --> config port --> uncheck snmp status
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Possibly a duplicate IP address
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • ES-OGT
        • Aug 2011
        • 129
        As silly as it sounds, change the network cable. That will solve most network drops you get when they're sporadic.
        • yakyitz
          • 245
          If the paper guides in the paper trays are not completely firmly flush against the paper, even though the machine registers the correct paper size it will go offline.
          • linuxgyro
            • Oct 2012
            • 45
            i have seen it where it will intermitenly not print because drawer 3 wont work. the reason i figure it is is that on my machines drawer 3 was set to default print from that drawer. i moved it to anther and it works just fine ever since.
            • ccwilliams3
              • Jun 2009
              • 22
              You have to uncheck the SNMP in the printer properties on the pc having the problem this is happening on loads of pc's on windows 7,
              • Venom
                • Nov 2009
                • 765
                I had one the other day, tray 3 disabled caused it to be offline. Paper was in wrong. Command Center said check tray 3, U906 fixed it.
                Teach your customers how to put paper in. Then bill them for recurrences.
