2550 j-12
  • Kirk
    • Apr 2011
    • 16
    2550 j-12
    I have a 2550 with 600k copies. I am getting a j-12 from cassette 2. I have changed the feed, separation and h-pick rollers on feed section. i have changed the clutch out. If you print normal protrait style no jam. If you try landscape it jams. also jams on legal and ledger paper through cassette 2.
    kirk
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: 2550 j-12
    trade tray 1 with 2 feed units and see if problem moves to tray 1
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • JR2ALTA
      • Feb 2010
      • 2028
      Re: 2550 j-12
      Of course this model doesn't have the traditional Kyo feed units that swap.
      But you should look closely at the registration switch, the rear side should have a spring to assist in the return. The spring disappears.
      • dickierock
        • 252
        Re: 2550 j-12
        Hi, is it jamming every time or intermittant?
        One thing to check is if the tray has been set to a specific size in the menu settings,as this may over-ride the auto paper size detect.
