Fs-2020 paper size error
  • Tonerkiller
    • Oct 2012
    • 668
    First Merry Christmas
    I have an fs-2020 that intermittantly jams at the reg roller. The display says paper size error, I have to turn the machine off to reset the jam. I replaced the tray tires and all three clutches. Any ideas?
  • HenryT2
    • 962
    Re: Fs-2020 paper size error
    Did you check the paper size switch ? Check the Registration Roller actuator to be sure it is not binding .
    Check the printer settings for paper type and size as well.
    You could also check to see what data is actually being sent to this printer; ex. are they sending a letter size doc with letter size paper in the cassette?
    Are these jams occuring with plain paper or with a different media?
    "The Serenity Prayer" . . .
    God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
    • Tonerkiller
      • Oct 2012
      • 668
      HenryT2, yes to all. We brought the machine in the shop because the problem is so intermittant. I have been printing manuals from my pc and getting the same problem as at the account. As for the paper size switch, I have found that when it jams and the jam is cleared I have to turn the machine off or change the tray size selector to a different size and back to get the machine to reset. he printer does have about 800k on it. The reg. switch seems fine.
      • HenryT2
        • 962
        Originally posted by Tonerkiller
        the printer does have about 800k on it. The reg. switch seems fine.
        AHA !!!! 800 K !!!
        We have seen this before on that high of a count ( we have some 3900's - 4020's with a mil and a half ) ...
        REPLACE the registration roller actuator and spring ...
        That actuator can get worn down at that high of a count ...
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
