FS-1128 displays 'replace process unit'
  • milldew
    • Mar 2010
    • 22
    But... what is the 'process unit'? The drum unit or the developer unit? I sifted through the ops manual and the service manual... nothing about process unit other than how to take out what appears to be the developer unit. I think its the drum. I feel kind of stupid to even ask, but like they say, 'a stupid question is one that is not asked'.
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Re: FS-1128 displays 'replace process unit'
    fs -1128 does not have a process unit.....check your model # again. A process unit is drum and dv unit all in one.
    I know what I know better than anyone else knows what I know.
    • JR2ALTA
      • Feb 2010
      • 2030
      The process unit is the drum unit.
      If you pulled out the developer, stick your head in there and your see the drum with two green loops to pull it out by.
      After you replace go to U251 to clear maintenance count and U111 to clear drum drive time.
      Dont bother cheating the machine, the process unit holds all the waste toner, so you're better of replacing it.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5006
        DK-150 / Drum Unit Kit ass'y pn. 92H493010 life 100.000
        Maintenance Kit MK-132 pn. 612810065 life 100.000
        MC-130 / Main Charger pn. 92HS93070 life 100.000
        • milldew
          • Mar 2010
          • 22
          I just ordered the MK-132, it only costs a little more than the drum. Thanks all
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            I'd think the process unit to be the developer. The machine will say Waste Toner almost full or throw a C7990 code. Though that message may come up when the counter is nearing it's end, so it may be the drum unit.
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • milldew
              • Mar 2010
              • 22
              Since i have to drive 80 miles to do it, I'm taking the whole kit. I wish Kyocera would get it together with their terminology.
              • Caldo
                • 69
                I have one of those older versions of the kyocera models, and mine is Kyocera KM1500. The process unit for my machine is the drum unit and the developer unit, all combined.
                • cwilli07
                  Have had this problem before, It is the DV unit. About the drum unit, on an 1128 you can pop the top left and right waste covers off when toner is nearing full and vac it out..
                  • giddyupngo
                    • Oct 2014
                    • 109
                    I just had one of these today with the message "replace process unit". It just means the U251 Maintenance count has broken 100K. I just reset the U251 counter to zero, and the message disappears. Since these are all out of warranty, and typically you would replace drums and developers only as needed, it would be a good idea to check the U251 count on each visit to keep it under 100K. Otherwise you will end up with extra service calls. I did empty out the toner in the drum, there are two squarish panels on the end opposite the handles that pop out. The drum was replaced in my case only 20K ago.
                    • The_Murph
                      • 96
                      Also, to piggyback on this thought of resetting counts, you CAN empty the waste out, however if you wait until it is full, the cleaning blade will be fouled and you have to replace it anyways. Its all contingent on PQ, obviously, If the PM count is reset when drums are replaced, you will see that the cycles tend to match up, its typically when someone changes out the drum for a pq or noise, etc that the counts get out of sync.
                      If you phrase your inquiry properly, you will get the answers you seek...
                      Good Luck ... You'll need it! HAHAHA!
                      ~Big Dan~
