km-2550
  • daveh12
    • Jul 2012
    • 157
    km-2550
    Ive a question about a Km-2550, when copying an original on single-sided, the copy comes out perfect.
    Then when duplex is selected for the same original, the copy has approximately 1cm missing on the right margin front and back. has anyone ever seen this before?
    have adjusted magnification, registrations, centre line and margins with no luck.
    any ideas appreciated.
  • Arc Angel
    Junior Tech
    • Jul 2012
    • 65
    Re: km-2550
    Does this only happen when you photocopy, or does also happen when you print?
    The secrete of staying young is to live honestly, eat slowly and lie about your age..... No man is so poor as to have nothing worth giving.
    • daveh12
      • Jul 2012
      • 157
      Print also yes.
      • Arc Angel
        Junior Tech
        • Jul 2012
        • 65
        Re: km-2550
        Than the problem most probably lies on the duplex unit. Check all the rollers. The transfer roller for one. If the image is coming out well one sided, than there shouldn't be anything wrong with the drum unit or the fuser unit. Also check the main charger, I have experienced problems like this where the main charger had a broken grid wire in it. Other than, I have no other advise for you right now. Good luck.
        • daveh12
          • Jul 2012
          • 157
          Re: km-2550
          problem solved when i removed the spring from the registration sensor. never saw that before.
          • JR2ALTA
            • Feb 2010
            • 2033
            Re: km-2550
            bookmark this page for when you ask about jamming
