adf
  • tcypy1961
    • 773
    adf
    what is the cause of skewing copies when using the document feeder(only when duplexing); placing original on glass manually no problem.
    Thanks!!!
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: adf
    Thanks!!!
    I am wondering how the hell you have 400+ posts.
    • Eric1968
      • 2458
      Re: adf
      Which ADF, which machine, what did you already do. More info...
      • luis8832
        • Dec 2008
        • 250
        Re: adf
        What unit is it and what type of adf? You know information goes a long way if you need help.
        • DWise
          • 895
          Re: adf
          Thanks!!!
          Well with the vast information given, my lowly-tech advice would be to stop duplexing...
          Do for one what you wished you could do for everyone. - Andy Stanley
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            Re: adf
            Thanks!!!
            can be!
            • tcypy1961
              • 773
              Re: adf
              Thanks!!!
              My bad; KM 4035 not sure of adf model #; I'm thinking SRDH 1 or 2; it's the only feeder I've seen on these machines.
              Thanks!!!
              • Jules Winfield
                • Jul 2009
                • 821
                Re: adf
                Check the spring pressure on each end of the white plastic strip opposite the slit glass. If the white plastic strip is crooked due to incorrect spring pressure on one side, then skewing can result.
                But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
                • madas
                  • Aug 2008
                  • 313
                  Re: adf
                  Check there is nothing in the duplex path for the Doc feeder, eg, bit of torn paper or staple.
                  madas
