fax setup
  • Max
    • Oct 2011
    • 566
    fax setup
    When i fit a fax option on to a copier do i need to input the fax number for it to work? Or is it just for information purposes when the fax comes out on the other end.
  • Eric1968
    • 2458
    Re: fax setup
    There's no need to input the fax number if it's a G3-unit. If you have a G4-unit then you must input the number.
    • Max
      • Oct 2011
      • 566
      Re: fax setup
      Thank you
      • madas
        • Aug 2008
        • 313
        Re: fax setup
        make sure you have the correct country code for your region.
        madas
