Help Kyocera 5500i Blankcopies after the PM
  • Techman1000
    • Dec 2010
    • 44
    [Misc] Help Kyocera 5500i Blankcopies after the PM
    I just did a PM on a 5500i & get blank copies with the new development unit not sure whats going on!
    The sheet that comes inside the PM kit says do U119, U930, U140,U127, u167, U464,U412,U410, thje U251 clears the Mant Counter!
    What happened to U130 are you still suppose to do this, even the manual on page 1-5-28 says do U140
    Anyway I still get a blank copy with the new development unit, so temporay i had to put the old devl. unit in just so they can make copies
  • dikyo
    • Apr 2011
    • 45
    Re: Help Kyocera 5500i Blankcopies after the PM
    Remove the rubber strip from the development unit before you install this unit
    (sea other threads 5500i)
    Groet,
    Dikyo
    • A\ztech
      • Feb 2011
      • 57
      Just had the same issue there's a rubber piece right in between mag roller and housing that's hard to notice (see attached pic)KM5500.jpg
      • blackandwhite
        • Aug 2012
        • 67
        Originally posted by A\ztech
        Just had the same issue there's a rubber piece right in between mag roller and housing that's hard to notice (see attached pic)[ATTACH=CONFIG]19173[/ATTACH]
        guys..is there any notification to remove the rubber piece.......because now we are hearing number of issues related to the same.....i hope there will be a information sheet with the new developing unit....if it is not..then ......kyocera ....go to hell......
        • darry1322
          • Oct 2010
          • 817
          Yes, there are instructions in the box to remove the sheet, but it blends so well that it can still be overlooked.
          • Techman1000
            • Dec 2010
            • 44
            Thanks a lot this was the problem, I would have never found this, looks like part of the devl unit & no instructions in the PM kit box about this!
