Accounting codes in Terminal Server 2008 R2 environment
  • roland
    • 3
    [Misc] Accounting codes in Terminal Server 2008 R2 environment
    I got a new Taskalfa 4500i which I configured to use accounting codes. When clients locally attach by means of netwerk printer, the code applied in the main properties windows (the most right tab), is also provided correctly to the printer. However , if clients connecting using a RDP session to the terminal server, these codes are not forwarded and thus meaning the print is invalid (accounting code unknown) .
    Is this a typically terminal server issue ?
