4550ci f000
  • Tonerkiller
    • Oct 2012
    • 668
    4550ci f000
    I have a 4550ci that intermittantly locks up and gives a f000 code. I can reset it but it has came back a couple of times. Any ideas of how to resolve it?
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: 4550ci f000
    There is a bulletin for all the Fxxx codes for the new Task Alfas...Blackcat I think has even added them into his code list sheet...but this is what is says
    F000
    CF000 appears in 3minutes
    30 seconds after the
    Welcome display continues
    Panel-Main board
    communication error
    1) Check connection of the harness (Panel to Main board), (Main board to HDD)
    and connectors and check function.
    2) Check contact of the DDR memory by detaching and reattaching. and check
    function. replace it if available and check function.
    3) Format the HDD and check function. (U024 FULL formatting)
    4) Execute the U021 Memory initializing to initialize the controller backup memory
    and check function.
    5) Replace the main board and check function.
    6) Replace the Panel board and check function.
    7) Retrieve the USBLOG and contact the Service Administrative Division.
    [Main-Panel Interface]
    Mainboard: YC12,YC17,YC30
    Panel borad: YC1,YC2,YC3
    If the LEDs are in the state
    belwo when the F000 appears,
    the DDR2 memory failure may
    be the cause. Check contact of
    theYS1 or YS2 with the
    memory.
    Memory LED turned on
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • Tonerkiller
      • Oct 2012
      • 668
      Re: 4550ci f000
      I did follow the trouble shooting guide. But I did not replace any parts yet. This is a new machine it is in our office. I hate to start throwing parts at it at this point. Any other ideas?
